Normale Version: TMC in a US Spec MINI
Ich will auf Englisch diese post machen...
This is for all people that might be searching the German forums on how to get TMC working in your US Spec MINI. There are two steps.
1. You must get the NAV in European mode. There are two ways to do this. You can take it to the dealer or you can reload an older firmware and then move it back to V27.1 (the current). This is for MKIV (DVD based NAVs only). When you set it to European mode, you will lose feet as they become yards and you will lost the emergency menu. However, you will gain the menus that have the TMC settings. If you do the downgrade and upgrade, it is at your own risk.
2. You will need a European CD boost that is made by Siemens (I believe). http://www.newministuff.com/boost.jpg
Above is a picture of one in cassette format. CD is also available.
Simply install the radio and then tune to a station that has the TMC feed. Simple as that. Smile
I have used it a lot here in Germany and love it.
As for my MINI2 Brothers and Sisters, I have not been posting as I am getting ready to move to Grafenwoeher. Tchuess.... eek!
enjoy grafenwöhr Devil!
One small annotation. The Boost is manufactured by VDO Pfeiff
Scotty schrieb:enjoy grafenwöhr Devil!
Well there you go... Anbeten Augenrollen Respekt
Great write up! Not sure though its for me. Correct me if I am wrong, but this doesn't work in the US ?
Scotty schrieb:[...]
vdo = 100%ige siemens tochter
