Normale Version: where to get brakepads for Stoptech ST-40
Hi, going down to ringrace some more, and as it's hopeless to get parts here locally I was hopeing there was someplace near nürburgring, or on my way there from Kiel I could buy pads for my Stoptech BBK, the calipers are the ST-40
I'm hopeing for semi-race pads like the ferodo DS2500 or similar, race only pads like DS3000 is ok as well.
the size of the pad is the same as Porsche models including the 944 Turbo, 1991-1994 911 series, 1992 968 and 1986-1991 928 so should be hope
p.s. I'll be at the ring from 18-28 of july , so other mini owners please say hello to the tall red-haired guy from norway Smile
I'm writeing this in english as last time I tried german the response was "geile" Wink
i only know the shop called "sandtler" where you should get them. it's more or less on the way from kiel to the ring
http://www.sandtler.de/katalogangebote/b...che_va.htm
you can check if they are available on the link above. the shop is placed in "bochum"
ahh perfect! I will call them up tomorrow and ask if they can check the stock for me, again thanks!
piebald schrieb:i only know the shop called "sandtler" where you should get them. it's more or less on the way from kiel to the ring
hello anders
here is the best way:
http://www.stoptech.de
order
and they are great!
sinzin
