Normale Version: OBD Bluetooth Navi Schnittstelle
Morgen zusammen,
wird auf der kommenden CeBit von Garmin vorgestellt und soll für ~ 100€auf dem Markt kommen.
Zitat:ecoRoute hd: Transform your nuvi into a real-time diagnostics computer
January 5, 2010 - posted in ecoRoute, Garmin Garage, On the Road,
[Bild: 6a00d83451bb7069e2012876a702b7970c-800wi]
For any driver who has ever been curious about what's really going on under the hood, Garmin's new ecoRoute hd provides many of the answers. By accessing onboard diagnostics and performance data, drivers can use a compatible Garmin nüvi to wirelessly monitor real-time vehicle diagnostics while accurately calculating ecoRoute data and driver challenge scores (speed, acceleration, braking, etc.) in an effort to conserve fuel and money through fuel-efficient navigation.
“When it comes to fuel conservation and vehicle upkeep, the real-time information provided by ecoRoute hd is the key to being a smarter driver,” said Dan Bartel, Garmin’s vice president of worldwide sales. “Garmin is known around the world for getting you to your destination efficiently, and now you can know how your car is performing every step along the way.”
[Bild: 6a00d83451bb7069e2012876a704bb970c-800wi]
By simply plugging the ecoRoute hd module into the vehicle’s standardized onboard diagnostics port (OBD II), safely mounting the transmitter clear of vehicle controls and pedals, and completing the easy one-time pairing with nüvi, drivers can start receiving the vital data from their vehicle and run diagnostic checks through nüvi’s intuitive interface before a trip to the auto shop is necessary. Drivers also get more accurate ecoRoute data, making fuel conservation easier than ever, and they can monitor their engine data (including temperature, RPM, emissions) and diagnostics through the Trip Computer screen and customizable Gauges screen. Drivers can then view Diagnostic Trouble Codes – with on-screen descriptions of some error codes – and reset the “check engine” light. ecoRoute hd will be compatible with many current and future nüvi models, including 1260, 1370, 1390, 1490 and 1690.
[Bild: 6a00d83451bb7069e20120a7a4954e970b-800wi]
Real-time data monitored by ecoRoute HD, which has an expected availability date of March 2010 for a suggested retail price of $149.99, includes vital diagnostics such as:
• Intake air temperature information
• Coolant temperature data
• Throttle position and engine load
• Intake manifold pressure
• Battery and charging system information
• Mass airflow rate
• Timing advance
• Emissions
Introduced by Garmin in 2009, ecoRoute is a free software update that helps drivers conserve money and fuel, easing growing pressures on personal budgets and the environment. In addition to “faster time” and “shorter distance” for route preference, ecoRoute lets nüvi users choose “less fuel” as a routing option as the best way to help save gas and money. Through ecoRoute’s Fuel Report, Mileage Report and fuel-saving tips, drivers can focus on fuel conservation even when they’re not behind the wheel. Fuel Report tracks fuel usage over time, and Mileage Report monitors mileage and fuel usage on a per-trip basis. Drivers can customize their nüvi to fit their vehicle by accessing the “vehicle profile” under ecoRoute in the tools menu. There, you can enter your car’s fuel economy and the current price of gas to help nüvi better calculate your savings. To find out if your nüvi is compatible with ecoRoute through a free, downloadable software update, go to www.garmin.com/ecoroute.
Find ich genial - bleibt aber immer noch die alte Frage - Wohin mit dem Navi.
Das ist wirklich geil! Also mein Navi ist ganz links an der Frontscheibe. Super - keine Sichbehinderung echt klasse
Wie geil!
Sollt ich über ein neues Navi nachdenken Head Scratch
Sowas gibt es schon lange fürs I Phone Pfeifen
Da kannst du dir alles anzeigen lassen. Sogar den Fehlerspeicher.
red_flame schrieb:Sowas gibt es schon lange fürs I Phone Pfeifen
Erzähl mehr???
Zitat:Sowas gibt es schon lange fürs I Phone Pfeiff
Das würde mich auch brennend interessieren. Iphone nutz ich breits als Navi.
Die Software heißt REV 2.0. Dazu wird ein ElmCanII-WLAN-INT Interfaces gebraucht. Der Rest erklärt sich von selbst. Pfeifen Geht im Übrigen auch mit dem I pod Touch.
http://itunes.apple.com/WebObjects/MZSto...253D_blank
Hier mal der Link für die App.
Bei youtube gibt es auch Videos davon.
Mann auch die gefahrenen Daten aufzeichnen. Top
Cool danke für die Info. Klasse Spielkram Top
Habe mir jetzt erstmal Dynolicious auf meinem Iphone installiert. Genau das richtige Spielzeug für einen sonnigen, verkehrsarmen Sonntgsnachmittag auf der Landstraße. Devil!
  • 0-60 Acceleration
  • Other Speed Tests (0-10 MPH through 0-100 MPH in 10 MPH increments)
  • 1/4 Mile Elapsed Time
  • 1/4 Trap Speed
  • Elapsed Time and Trap Speed for standard intervals (60′, 330′, 1/8 Mile, 1000′Wink
  • Lateral G’s (current and peak)
  • Braking G’s (current and peak)
  • Horsepower (wheel and/or estimated crank)
  • Friction Circle (max G’s in 16 directions)
  • Downloadable Timed Run Graphs
  • Downloadable Skidpad Graphs
http://www.bunsentech.com/projects/dynolicious/
Scheint wohl ziemlich genaue Werte zu liefern.
http://www.youtube.com/watch?v=0-DFbJQbeSY
Hier noch ein Vergleich zur Vbox.
http://www.motivemag.com/pub/news/Tested...VBox.shtml
